It is currently Sat Nov 23, 2024 5:58 pm
PostPosted: Mon Feb 20, 2023 2:57 pm
First name: Daniel
Last Name: Russin
City: TUCSON
State: AZ
Zip/Postal Code: 85743
Hi all, I'm a longtime enthusiastic lurker who's finally going to try and modify/fix something.
I have an octave mandolin with a custom rosewood (?) floating pickguard that doesn't fit well. It sticks out past the edge and slightly curves away from the top of the instrument. It arrived with the furthest tip cracked off, which I already glued w/ titebond original. The backside of it is covered in what looks like rattle-can flat black paint.
I think I need to do two things - flatten it, and trim it so it fits in the case without being pinched. I also need to install a pickup, which will be an adventure for another time (Schatten HFN, I hope).
How would you handle the trimming? I have access to a scroll saw (in a few months...) and have some skill with a coping saw. I also have an assortment of files, sandpaper, etc. and an abundance of patience. I'm thinking I will go with a slimmer, more modern profile, perhaps like what Northfield does with their archtop octaves.
As for flattening it, I wonder if it will really be necessary after it's trimmed to size. Opinions welcome!
Last edited by Melt in the Sun on Mon Feb 20, 2023 5:24 pm, edited 1 time in total.
PostPosted: Mon Feb 20, 2023 4:38 pm
If it was in my shop I would shape it with a disk sander for the outside curves, and a drum sander for the inside curve. It doesn't look very warped so I would not try to flatten it.
You might want to get an app to make your photos smaller to fit the page.
PostPosted: Mon Feb 20, 2023 5:25 pm
First name: Daniel
Last Name: Russin
City: TUCSON
State: AZ
Thanks Barry. I do have a dremel with the tiny sanding drums, so that's an option. Edited my post so the photos are no longer obnoxiously large.
PostPosted: Mon Feb 20, 2023 8:00 pm
A dremel is way too small for that kind of work. You need 1 or 2" diameter sanding drums. If you can't do that then use files or sandpaper glued to a board.
And depending on how much material you need to remove, a coping saw or scroll saw would work great to get close, then follow up with the file or sandpaper.
PostPosted: Tue Feb 21, 2023 10:45 am
First name: Daniel
Last Name: Russin
City: TUCSON
State: AZ
OK - i don't have that kind of drum sander! Sounds like I need to sketch out some designs and make a decision. Thanks for the help.
PostPosted: Tue Feb 21, 2023 12:58 pm
First name: peter
Last Name: havriluk
City: granby
State: ct
Zip/Postal Code: 06035
If hand-sanding is possible, pill bottles and doublesided tape come to mind for inside curves.
Peter Havriluk
PostPosted: Tue Feb 21, 2023 6:34 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
I strongly suggest you make several cardboard mock-ups of your new shapes and put them on the body. Take your time and look at them often. It is surprisingly difficult to come up with pickgiard curves that feel right with the body shape. Make sure you have one you like before you start mode gong this one.
On e you have the shape you like, cover the guard with masking tape, draw out the new lines and work towards that line be. Once you get close, slow down and slowly sand toward the line keeping the curves fair.
Bryan Bear PMoMC
PostPosted: Mon Feb 27, 2023 11:19 am
First name: Daniel
Last Name: Russin
City: TUCSON
State: AZ
Soliciting opinions, if anyone wants to share!
First is modified from a Benedetto design; I think this might be my favorite, but these don't typically have brackets.
Second is modified from the Northfield design, plus I added a swoop at the bottom (that I probably wouldn't keep)
Third is a gibson L-48 shape.
I've been toying with the idea of scrapping the bracket and making the whole thing much smaller, but am uncertain if the guard is stiff enough for that to work.
PostPosted: Mon Feb 27, 2023 11:37 am
You are still going to need the bracket for support.
I like the third one.
PostPosted: Mon Feb 27, 2023 2:21 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
I think I like the third one too. It will also show the least of the bracket/rod.
Bryan Bear PMoMC
PostPosted: Mon Feb 27, 2023 2:32 pm
First name: Daniel
Last Name: Russin
City: TUCSON
State: AZ
Thanks Barry and Brian. No matter what I do there's going to be no hiding the threaded rod - that's OK with me! #3 was originally my first choice but I was warming up to #1; I think I've tossed #2 at this point. I'll look at it for at least a few more days...
PostPosted: Mon Feb 27, 2023 4:42 pm
I like the straight edge on the first one, which contrasts nicely with the body curves. But I might still bring the bottom corner to the bridge like the other two examples. Maybe keep the entire bottom edge of the original pickguard.
PostPosted: Wed Mar 08, 2023 3:13 pm
First name: Daniel
Last Name: Russin
City: TUCSON
State: AZ
Well it's done. I don't love the acute angle between the guard edge and the bracket, but it's time to stop second guessing and start getting used to it!
These users thanked the author Melt in the Sun for the post: Bryan Bear (Wed Mar 08, 2023 5:02 pm)
PostPosted: Wed Mar 08, 2023 5:02 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
Good work, I'm glad you are satisfied.
Edit: I made that response quickly then got to thinking that it may have sounded snarky. I didn't mean it to. I was trying to say that I was glad you found the shape that was right for you and didn't end up disappointed after putting tools to the only PG you had. . .
Bryan Bear PMoMC
PostPosted: Wed Mar 08, 2023 6:04 pm
First name: Daniel
Last Name: Russin
City: TUCSON
State: AZ
Thanks Bryan. I think I like the shape; I'm just one to second guess all the details. Nobody will ever look closely again but me!
These users thanked the author Melt in the Sun for the post: Bryan Bear (Thu Mar 09, 2023 2:12 pm)
